4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Cazvi This message was authored by: Cazvi
Re: Sky Glass Power up Issues 19-9-24
Just managed to get my sky glass up a running by Ethernet/hardwire to internet as like many others got so far and then would not connect had to completely reactivate from scratch through this method but hopefully it helps others.
This message was authored by Northolt55 This message was authored by: Northolt55
Re: Outage
Can't do a factory reset as suggested by sky in the link as tv won't even turn on !
I feel Sky should be updating us more as to what the actual 'issue ' is and absolutely give customers a refund
This message was authored by DanJC1975 This message was authored by: DanJC1975
Still no joy with mine! Switches on now but will not connect to my broadband. Have tried all the suggestions multiple times with nothing changing. Think whatever happened has broken it so will expect a replacement
This message was authored by JW6 This message was authored by: JW6
Re: Sky stream not working
Its all very well engineers are working on it.But after in my case oveer 24 hours,i would hope Sky will be offering a reduced bill next month quid pro quo,and as mine recently increased.BEFORE the increase it ran well enough ironically.
Kev
how can some of us do a factory reset when tv won't even turn on
please advisr
This message was authored by Bellco83 This message was authored by: Bellco83
After sky stream not working for 2 days, my puck is now in set up mode.
Now have another issue, it wont accept my pin so cannot complete setup. Im stuck in a continuous  loop on 'Your Pin Settings' page. It wont accept my pin, ive changed the pin successfully 4 times but when I enter new pin to proceed to next change, says pin is wrong.
This message was authored by Skyglass123 This message was authored by: Skyglass123
Re: TV has power, no red light, black screen, side microphone light luminates momentarily.
I tried pressing the TV side on/off button for 20 secs and the TV went through reboot. Not sure if I had to borrow another pair of hands to turn power off at plug whilst I held the button in.
All is well on the end, TV works again.
This message was authored by lettice This message was authored by: lettice
Try this,
Turn off your Sky Glass tv or Sky Stream at the mains
Whilst it is off, reboot your broadband router.
Also if you have an ethernet cable attached to your Sky Glass TV or Sky Stream puck unplug it and plug it back in again.
Once your broadband router is back on and working.
Follow this procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
This message was authored by Lew_ov_pally This message was authored by: Lew_ov_pally
My tv still not working
My TV still not working two days running now fuming
This message was authored by BrokenGurl62 This message was authored by: BrokenGurl62
That's exactly what mines doing just stuck on incorrect pin. I've reset the pin and shock doesn't work.
@Killgore77 wrote:
Mine isn't working! Won't recognise my broadband!!!!
Try this,
Turn off your Sky Glass tv or Sky Stream puck at the mains
Also if you have an ethernet cable attached unplug it and plug it back in again.
This message was authored by Mark39 This message was authored by: Mark39
@Northolt55 An unlit power LED doesn't mean the tv isn't getting power. The recovery process worked fine on my Glass even though the red LED wasn't illuminated. Just follow the recovery instructions carefully
This message was authored by docer64 This message was authored by: docer64
@lettice do you know of a work around for being unable to proceed past the link your account screen? I am able to input the code via a web browser and submit but it does not effect the tv.
Tried factory resets, restarts, hard resets but no joy.
This message was authored by Jporch316 This message was authored by: Jporch316
Same here .....
there were no lights on at all - but the fix worked as intended
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
This message was authored by ROCKG13 This message was authored by: ROCKG13
Re: Outage
Second day no services tried factory reset however never gets passed pin code. Even after submitting correct details on file plus changing pin?
Time for change and to go to other service providers.
On another note why don't sky send a generic email to effected customers. With apologies for the lack of service plus timescale to rectify the issue. Enough said hopefully back on soon?
Locked
