4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Jporch316 This message was authored by: Jporch316
Re: Sky Glass Power up Issues 19-9-24
@docer64 wrote:
@lettice do you know of a work around for being unable to proceed past the link your account screen? I am able to input the code via a web browser and submit but it does not effect the tv.
Tried factory resets, restarts, hard resets but no joy.
Can you try a browser on a different computer or mobile ?
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
This message was authored by docer64 This message was authored by: docer64
@Jporch316  Yep, tried 3 different browsers on phone and laptop. Used incognito on chrome, 4G on my phone, as well as WiFi. Literally tried everything I can think of.
This message was authored by lettice This message was authored by: lettice
When you put in the code, there is a some kind of back key if I remember right on the page ( not the browser back key),  try that.
or try the activation using another browser or device .
Yiu could also try this alternate link;
Make sure you have logged into your Mysky account in your browser before trying.
https://www.sky.com/productsettings/streaming-tv/activate
This message was authored by DanJC1975 This message was authored by: DanJC1975
@lettice Have done this multiple times
This message was authored by Bargate This message was authored by: Bargate
Re: Cant link Puck to my account.
Same issues.  Re loaded sky software as advised. I have a "device PIN number" to connect to my account. Circulating between the oops message and being stonewallled by Sky call centre.  Not sure what to do next. The automated message says the "engineers are working on it."  Frustrating!
@lettice I have unfortunately attempted all of the suggestions below to no avail.
This message was authored by R1char8 This message was authored by: R1char8
@lettice Have tried again this morning following all the advice closely including restarting my router, exchanging cables, but the process does nothing, the led never flashes and the set never powers on.
This message was authored by Themuts This message was authored by: Themuts
Re: Martin my sky glass TV is not turning on
Are sky compensating us for this
This message was authored by mmmmmmxox This message was authored by: mmmmmmxox
no, it hasn't been working for me!
Can you start the recovery process again from the beginning ? Do you have more than one sky account ?
@Jporch316 I have completed the recovery process multiple times with no joy. Unfortunately, I only have one account.
This message was authored by Kay0x This message was authored by: Kay0x
3 days and still no Sky!? What’s going on? Just keep being told they’re fixing it
Sky stream has been off for 3 days, any update on how long it's going to take to fix? Chorley area
This message was authored by Dazzasky This message was authored by: Dazzasky
For what? You have posted in a thread from May @Themuts
This message was authored by chellebelle1 This message was authored by: chellebelle1
i have tried multiple times and with multiple browers and still not working sky are no help and we are paying for services we can't even use my account shows i have an active puck and can't activate puck so confusseing and irriating now and sky just say keep resetting it will work fed up of trying now when are sky going to take responsiblity and sort this problem out for eveyone as what they tell you doesn't work for everyone
This message was authored by Scors This message was authored by: Scors
Hi all,my sky glass tv has suddenly stopped working,ive tried all the resets and remote resets andd
Hi all,
My sky glass tv has stopped working, ive tried all the normal reboots and nothing works,I still have a backlit on for the remote and new batteries,so that's not the problem.
The standby light is not showing on the tv, it's been unplugged overnight but still nothing.
Any ideas would be welcome
Locked
