4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Heidi1174 This message was authored by: Heidi1174
Re: Sky Glass Power up Issues 19-9-24
Mine isn't a sky glass TV it's 2 sky stream puks
This message was authored by James+armer This message was authored by: James+armer
My sky glass has updated but I'm still stuck on trying to link my account to sky.com/activate. The website hasn't been working now for a good 3 hours. Can't seem to get through to anyone on the phone either 😞
This message was authored by HayleyCB This message was authored by: HayleyCB
Re: Sky glass
Also when requested to go to sky activate account or whatever drivle it says, make sure u are logged into your account other wise u will just see a big red error message
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Karen1212 wrote:
I've been waiting on the phone for ages too.
@Karen1212
I can't see the benefit of calling Sky. The most up to date information is in post 2 of this thread. An agent won't have anything different to tell you.
This message was authored by horace This message was authored by: horace
@Fothergill1
Yes!
I've noticed a few of the more recent posts in this thread are by people who have previously tried the fix suggested by Sky only to have it fail, then returning to say they re now up and running haveing realised they hadn't quite got the process right the first time.
I think there is a strong case for Sky to update their advice with a little more detail in the instructions.
This message was authored by KMH7 This message was authored by: KMH7
My sky glass tv won't connect to the internet. Have done all the resets & can't get past Network setup. Have had the broadband checked & all is working ok.  Been round in circles on & off since last night. Very frustrating.
This message was authored by Mark39 This message was authored by: Mark39
What's happening when you try to activate?
This message was authored by BobW2 This message was authored by: BobW2
Re: Hello my sky to obtained via a puck has not worked since yesterday evening . Am I alone with thi
I'm the same, puck not working,  but Sky WiFi is. All "help" from Sky i've seen is about Sky glass TV not a stand alone puck.  Tried their "Virtual Assistant" this morning, complete waste of 45min.
This message was authored by Lauren222 This message was authored by: Lauren222
@Chrisee I have sky glass , I have done the process too many times now even when I was on the phone to sky, I'm back on with sky now to find out the next steps as the tv isn't doing anything on a hard reset
This message was authored by Karen1212 This message was authored by: Karen1212
Thank you
This message was authored by Steph02011 This message was authored by: Steph02011
I am assuming this is a national issue then, and not just affecting people locally?
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Paul841 wrote:
Does Sky have a timeframe when this fault be rectified as have unable to turn my 43 inch tv for nearly 24 hours.
@Paul841 The published solution worked for me so it you haven't already done so follow the procedure at the this LINK
Select the appropriate button for Glass or Stream puck.  Good luck 🤞
If my post has solved your issue please mark as an "Answer"
This message was authored by paulp74 This message was authored by: paulp74
Thanks, this has fixed my Glass & Puck, I left the Ethernet cable in and it completed an update then went through setup.
This message was authored by Skelpy This message was authored by: Skelpy
It's ridiculous... Pay through the nose for em and can't even us em. I mean I have to go to work till 5am now but I'll see if they work when I get home.
Locked
