4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Changed PIN but keeps saying Incorrect PIN- ATTEMPT 0 OF 3
@Symonsmark wrote:
I had to reset puck. Downloaded software updates. Put pin in  Incorrect PIN. Went through forgot PIN but new PIN gives Incorrect PIN attempt 0 of 3.
The resolution to the PiN issue should be to just unplug the device for a couple of minutes and then plugging it back in.
Sky Stream and Sky Broadband customer
This message was authored by Debs2020 This message was authored by: Debs2020
Re: Sky Glass Power up Issues 19-9-24
My glass tv not working not even got the red light
This message was authored by Wardie2 This message was authored by: Wardie2
My sky glass tv won’t turn on
My tv won't turn on. I have tried everything since yesterday. No answer from sky dunno what to do?
This message was authored by Lonesome+dove This message was authored by: Lonesome+dove
Sky glass
It's ridiculous my sky glass has been off from last night. I was waiting on the phone for 2 hours this morning trying to contact them when they finally answered I was told they didn't know if it would be fixed today. They said everyone who was affected was getting £5 credit from their next bill wow . They are a joke. Anyone know when it will be back on please
GD1
@Debs2020  Please see the post marked as Answer
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
This message was authored by Nicecc This message was authored by: Nicecc
Tried this several times and still not working
This message was authored by SteveG13757 This message was authored by: SteveG13757
Sky Stream isnt working. Been holding on the phone for over an hour!!!!
I've tried the steps provided, they don't work.
Can somebody contact me please from @Skytech
This message was authored by lettice This message was authored by: lettice
@James+armer wrote:
Has anyone managed to get past the link your account screen. This is a ball ache. Still having problems getting onto the sky.com/activate website. Comes up saying ' ooops there has been a problem' I've been trying for an hour now
Would suggest logging into your MySky  account first in your browser.
https://www.sky.com/myaccount
Then, once logged in, open a new tab in the same browser and enter the full url  manually into the address bar as below;
https://www.sky.com/activate​
This message was authored by Jack373 This message was authored by: Jack373
Hi all,
my Glass Tv will not connect to the broadband router or internet. It's been like this for almost 24hrs. I have tried unplugging it and restarting numerous times and nothing changes. I have tried calling sky but gave up as I was on hold for 2 hours and 30 minutes. Is anyone else having the same issues?
This message was authored by Daniel0210 This message was authored by: Daniel0210
@SteveG13757
No one from Sky will contact you, in fact they won't know who you are from a forum user name. Also the name you've tagged is a customer like us. Follow the advice on post 2.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
This message was authored by jibbajabba38087 This message was authored by: jibbajabba38087
Re: Sky glass will not turn in and no red LED
I've just had this. Seems the fault was an update from sky (not that they admitted it though). We were told to turn the power of at the mains but no need to unplug then hold the power button down on the TV and turn the power back on whilst keeping the finger on the power button. Wait for the LED light to flash (takes about 20 seconds) then let go of the power button  button and it should do a reset
This message was authored by Mel112 This message was authored by: Mel112
Is everyone still having problems with their stream pucks. I've followed the steps to reset it which worked. Linked sky account worked but then tried to pop pin in and now blocked me from signing due to wrong pin (which it wasnt). I've been off since early last afternoon and still no luck
This message was authored by Ingilybob This message was authored by: Ingilybob
@MarkGoldsmith tried it, doesn't work for me and a lot of others too. It's not a fix-all solution, it's something on Sky's end.
Unfortunately it's going on way too long and Sky aren't giving much of an explanation.
This message was authored by Alan155 This message was authored by: Alan155
Re: My sky glass tv isn’t working properly
What is the number for level 2 support it's a joke this tried everything and it's still stuck on standby
GD1
No one from Sky Tech who you've tagged (BTW that is a customer id and no doubt will regret using such a tag), no one here has acccess to your account details, in any event the post marked as answer should help
Locked
