22 Apr 2024 05:28 PM
Yes its been addressed i made a typo......
22 Apr 2024 05:29 PM
Edit my post then...
22 Apr 2024 05:31 PM
@ThePope27 I was only pointing it out to you so you know for future reference and superusers cannot edit other users posts
22 Apr 2024 06:05 PM
But superusers can change other peoples answers tho can't they 🤬
22 Apr 2024 06:11 PM
@ThePope27 yes superusers can amend answers, where the incorrect post has been picked as the answer a superuser can amend it to the correct answer
22 Apr 2024 06:17 PM
Seems like certain people are abusing that...
22 Apr 2024 06:26 PM
@ThePope27 The correct answer has to marked to let others with the same problem know what the full answer is
as some people, mark their response as the answer when its not, others mark the first response as the answer when it might not be correct sometimes the first correct answer is missed by the op other times although an post is marked as the answer its not completely correct and a fuller complete explanation is marked as the answer.
I've had many of mine changed by other superuser and Sky staff and have changed some of my own from being correct as it was the first answer and wasn't what actually helped helped the op
22 Apr 2024 07:11 PM
Posted by a Superuser, not a Sky employee. Find out more@Laing1 I know this has been discussed elsewhere but I would be in favour of the wording being changed from "Answer" to "Solution" as this would remove a lot of the confusion..
