121
This discussion topic is read only This discussion topic has been answered Discussion topic: Discussion topic:There is a technical fault. Please try again later
Locked
This message was authored by: RMMTS
Re: Discussion topic:There is a technical fault. Please try again later
Hi Guys,  has there been a solution to this issue?  Both of my pucks have been working fine no technical error messages etc.  Haven't had to reset/power cycle for 3 days now. ......... Whoopee
This message was authored by: KevNewMedia Answer
Posted by a Sky employee
Hi Everyone
Thank you for your patience whilst we worked through this problem.
Our support teams have confirmed that this issue should now be resolved. If you encounter the same/similar error message, it's likely that the problem that you have is not linked to this fault. Can you create a new post and the Community will be on hand to help further 🙂
I'm going to close this thread and thanks again.
Kev
Community Manager
Locked
Answered - Go to Answer
