Discussion topic: Discussion topic:There is a technical fault. Please try again later
Message posted on 15 Aug 2025 04:47 PM
							Re: Discussion topic:There is a technical fault. Please try again later
The Disney plus tech support has told me to call Sky and switch off IPV6
This is because I cannot play anything on Disney plus. We tried for an hour to solve the issue.
Message posted on 15 Aug 2025 05:03 PM
							Re: More stream nonsense
It's just dreadful.
Imagine if you were trying to drive forwards in your car, but the dashboard said 'sorry, forwards isn't available' despite you moving forwards. Then it said 'sorry there's a technical error' and the only way to fix it was to stop the car, get out, then wait 2 minutes while it restarted.
That car manufacturer should be a laughing stock.
Message posted on 15 Aug 2025 06:39 PM
I have exactly the same issue. Is this a Sky glass problem? My internet speed is very good. Sky seem impossible to get in touch with. They may have to get kicked into touch very soon.
Message posted on 15 Aug 2025 06:59 PM
I keep getting this too : had to reset 3 times in the last hour
Sky Glass TV Gen 2. 55” Volcanic Black
1x Sky Stream Puck
Sky Ultimate TV & Netflix Premium
Sky Sports Complete Pack
Sky Cinema
TNT Sports
Sky Ultra HD & Dolby Atmos
Sky Whole Home
Ad Skipping Pack
MUTV
Virgin Media Broadband Gig1
Message posted on 15 Aug 2025 07:00 PM
I think it is a problem with the streaming system that goes both to Sky Glass and the Sky Stream puck. I am definately kicking them into,touch, not just the problems with the streaming service, but their prices and inability to contact folk, the website help center sends you round in circles and if you do call them you get asked to do all the stuff you have done before , ie switch on / switch off , reset the puck , pray to the gods of the internet then they send you out a new puck and the saga starts again.
Message posted on 15 Aug 2025 07:02 PM
I'm all for the streaming future . But it's times like this I wish I had sky q still
1x Sky Stream Puck
Sky Cinema
TNT Sports
Sky Whole Home
Ad Skipping Pack
MUTV
Message posted on 15 Aug 2025 07:46 PM
i've had the same problem on all 3 of my stream pucks since yesterday. pain in the backside.
Message posted on 15 Aug 2025 08:48 PM
							Puck keeps freezing, crashing while watching ihd
Does anybody else's pick keep on freezing and then rebooting about every 20 minutes if they try watching football or f1 in uhd? Box is wired direct to modem and is getting 1000mps so it's not the broadband speed.
Message posted on 15 Aug 2025 08:58 PM
Having the same problem speed test shows running 120+ tried multiple resets nothing seems to help. It now seems Sky Glass is not fit for purpose and they need to sort out these pr
Message posted on 15 Aug 2025 11:39 PM
Getting the same . Scared to change channels in case I get the technical fault error 😂
1x Sky Stream Puck
Sky Cinema
TNT Sports
Sky Whole Home
Ad Skipping Pack
MUTV
Message posted on 16 Aug 2025 08:54 AM
I'm getting a speed of 10.38 which is not good enough. Sky Glass is way more expensive! I had Sky Q with 3 boxes and now only have one puck so a third of the service and cannot connect anything else to my broadband.! Shocking and even worse since 'upgrading' to Sky Fibre!
Message posted on 16 Aug 2025 09:11 AM
I've not seen that technical fault message for many months. Not that I have ever seen that message much during my 16 months or so of Sky Stream.
But yesterday, it happened twice to me on one of my pucks, about five hours or so apart. During that time was flicking the Sky Sports channels a lot and through the Sky Sports app mostly with a bit of Disney+ and some Sky channel playlist new episodes.
A settings restart sorted it both times.
Was fine all evening and into the early hours.
Both pucks are on QS036.021.01P and 2.50.6 UI
Message posted on 16 Aug 2025 09:16 AM
Reset does work but it can happen again repeatedly throughout the day, has been ok for a few hours, my puck is on QS037.041.00P so unsure if this a new update which is running parallel with my issue since Thursday
Message posted on 16 Aug 2025 09:31 AM
The Q37 build is pushed out generally for the newer 'V2' puck. But, we have seen a few others with the 'V1' puck that have moved to this build.
Have you recently in last few months moved to Sky Stream?
For clarity on the 'V2' puck:
It is not a Gen2 puck, like the Sky Glass TV is an upgrade in specs to the Gen1 TV.
There is no expected performance difference to the current puck.
Expect, its just an alternative chipset from another supplier. Something many hardware manufacturers do to help steady supply chains.
The newer Puck has a smaller power cable plug end.
You cannot request one as a replacement for your current puck and as far as we are aware there is no plan for any replacement of a current puck with this one.
But expect going forwards, new customers will be sent one or the other.
Message posted on 16 Aug 2025 09:32 AM
							Puck: there is a technical fault
My stream puck is having regular technical faults when I try to switch channels. I restart the puck at least theee times a day to work around the problem.
is there is a way to talk with an Ursula support rep rather than the useless chat support ?
