Discussion topic: Wifi always disconnecting
This message was authored by Kimd6189 This message was authored by: Kimd6189
Our wifi connects keeps being cut off. When i checked on sky it shows everything ok but mobiles/tablets etc lose all connection and we have to restart our router. This happens atleast twice a day. Any suggestions?
thanks
Re: Wifi always disconnecting
@Kimd6189  Please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Kimd6189
@GD1
thank you
Router Statistics
System Up Time: 01:01:41
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 859.973 1949050 0 0 0 01:00:28 LAN Up 9423 8031 0 0 0 01:01:41 WLAN Up 1949321 852894 0 0 0 01:00:43
Broadband Link Downstream Upstream Connection Speed (Kbps) 79126 20000 Line Attenuation (dB) DS1:4.1    DS2:9.5    DS3:15.5 US0:2.6    US1:7.9    US2:11.7 Noise Margin (dB) DS1:6.6    DS2:6.4    DS3:6.5 US0:13.2    US1:9.6    US2:9.2
@Kimd6189  Was this yourself restarting the router with just over an hour on the system uptime?
Kimd6189
Yes, i restarted the router an hour before. This is what i have to do each day to get it to work again....:( @Highlinder
@Kimd6189  The next time it happens can you login to the router and the same router stats for the community as when the router is restarted all of the evidence is wiped away.
Kimd6189
When the router is not working it does not allow me how to view the router stats. Sorry not technical at all so unsure what to do
Kimd6189
When the router is not working it does not allow me how to view the router stats. Sorry not technical at all so unsure what to do @Highlinder @GD1
@Kimd6189  If at the point your router is down run the test in the link below.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
