Discussion topic: WiFi speed says is good but keeps disconnecting
This message was authored by James2208 This message was authored by: James2208
I keep checking my service on the app and it says the speed is good and is working good but I keeps disconnecting every 10 minutes
James2208
Re: WiFi speed says is good but keeps disconnecting
I also reset the box and it won't work
This message was authored by jellyfish29 This message was authored by: jellyfish29
Mine keeps doing exactly the same it's driving me mad
@jellyfish29 & @James2208 if you want advice from forum members post your hub's connection stats see Find your Sky Broadband router statistics
I tried but when I enter admin and password or sky it just clears the boxes and aoea nothing
@jellyfish29
Make sure your not using Safari on an Apple device
I am NOT a Sky Employee
