34
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: Kandee
WiFi not working
WiFi been playing up
for a few weeks now it kept dropping but tonight it's not working at all 🤷🏻‍♀️
Re: WiFi not working
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If it isn't and you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by: SKY9FC81
Same with us with 1 orange light
Avatar for Kandee
It says there is no issues with sky but clearly there is somewhere as I see quite a few here saying theirs is not working, it's frustrating isn't it!
I know, I keep refreshing and it's telling me my broadband etc is all working.
Sky needs to sort this ASAP
This message was authored by: AJ310
Mine's not worked since the afternoon yesterday. I've tested my connection and I keep getting told it's good. It's not good because I don't have Wi-Fi!
This message was authored by: Cshoe
Same here, I have work in the morning and work from home. SKY! Please sort this out! This isn't acceptable!
This message was authored by: Mix0182
My broadband is out too. South East London. Happened a few times now and its more than frustrating when all their checks say everything is working perfectly fine and as it should! Always the same. I have no tv ariel either so i'm stuck with nothing.
Avatar for Kandee
Yes it's the same with me, I'm in Northampton and no tv, no doorbell no baby cam, pet cam or anything and mine says all is working good too, I panicked thinking one of my dogs had managed to get to and chew through the wire or something but no it's just SKY!!!
Yep, mine's down in Dartford.
This message was authored by: Rrmm903
Also down in Bexley
Voice Orange light and no Internet - super annoying
 are they scheduled maintenance
This message was authored by: Dart2
same to me , WiFi is not working in Dartford!!
This message was authored by: smorgankkelly
Down in Bexley. Diagnostics  say fine. Frustrating.
Oh god thats even worse of a situation! I hope it gets sorted soon . Cleay not just a local situation then. I wrnt and checked everything too thinking my cat had done something like knocking it off or catching a cable. I suffer with mental health problems and neutodivergance struggle with the silence especially at night, I have to habe the tv on. With no communal arial I rely on the broadband to get free view if the mini box plays up (which it does a lot). But there is just nothing yet again for about the 4th or 5th time this year that i'm aware of and tbere is nothing we seem to be able to do because the tests all say everything is perfectly fine and functioning.
This message was authored by: DaveMag
Yes mine is down in dartford as well!!
Same here, I'm a vulnerable adult and this has left my security system down for the night. This happens far too often
