34
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: Ka53
Re: WiFi not working
No not had this before it recently got changed over to the fibre and had probs since the change
@Ka53 It is not easy to workout from your post so going to do this, had the sky black hub on the copper connection it was fine, you can say how long for,  then Full Fibre got installed few weeks ago and now it's dropping the Internet connection, i see that as, ALL the wifi bars disappear when i look at my device. Then what does it take to get it all working again, do you have to go switch it off/on and five minutes later it's back up to the 4 Green lights again until it falls over!
Anything not correct just say!
This message was authored by: Jez07
every device in house has this pop up and we have 4 phones, 3 iPads, 1 Xbox 3 televisions and I work from home it's unacceptable I can't get anyone on the phone!!
This message was authored by: Alexlc
WiFi very weak. Rebooted still issues
This message was authored by: StitchUp
Recently the WiFi from the Sky router is unavailable in rooms where is once worked fine! We haven't changed anything or placed anything that might obstruct the signal = baffled!
Can I use an access point connected to a spare RJ45 socket in another room to spread the signal?
Answered - Go to Answer
