33
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: Rrmm903
Re: WiFi not working
It's the fact diagnostics say it's fine! When it clearly isn't
When this happened last time it was maintenance and came back on at 7am🤷
This message was authored by: Mix0182
Diagnostics now say nothing is working but there are no issues in the area (bexley/Dartford) Can't run further checks as the system isn't working
Now says "there's a problem with your broadband, lets fix it" Outage in your area: no And given me an option to book an engineer...
This message was authored by: Loujess
I'm in Scotland and having the same issues I just got new fibre broadband put in last week did not expect it to not be working already! Also when doing a check it says everything is ok but it's not cause my phone or iPad aren't loading for anything
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If it isn't and you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
This message was authored by: Ka53
Hi
I have no WiFi ever since we changed to the open reach one the WiFi keeps dropping and no it won't connect to anything
@Ka53 When did you change?
Mid October was fine before moving it over now it keeps dipping off
@Ka53 Is it currently working or not, what is it you see for error's do lights change hub or whatever your connection is Full/Partial Fibre etc!
It's on now but when it goes off on the box the lights are off on the WiFi and Internet power light is on and voice light goes orange it's gone off 3 times today
@Ka53 There are 4 lights on the sky broadband hub.
1. power that is always Green.
2. internet that is going out so no light showing.
3. wifi that is always Green just like the power light.
4. voice that goes to an Amber light.
You can also see the about lights below!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on!
It's just gone off again
Green light on power light
No light on WiFi
No light on Internet
Amber light on voice
I work from home this isn't a great service
Thanks for your help anyway
@Ka53
@Ka53 Got your sequence now, very surprised at the wifi light going off, have never ever seen that, but aside, are you connected on a Full Fibre connection or on a OR Master Socket telephone line!
Answered - Go to Answer
