10
This discussion topic has been answered Discussion topic: Switching to Fibre Sky Q Hub question
This message was authored by: Sleepy7
I have a BT engineer due to switch us from copper to Fibre next week (arranged by Sky).  The Sky website says we don't need a new router, we have the Sky Q one with 3 lights (no voice light and no socket on the back for a direct phone connection).  We have Sky Talk but how do we physically connect the phone to the router?  Currently it connects via the adapter that came with the Sky Q hub and that adapter plugs into the BT socket.  When the switch to fibre happens I expect the existing BT socket to be obsolete.
This message was authored by: cookiemonsteruk Answer
Re: Switching to Fibre Sky Q Hub question
@Sleepy7
Hopefully its the upright black broadband hub sr203 or the  sky mx white hub sr213. Get back to us if you still haven't rec'd it
@Sleepy7
What speed where you told you'd get?
One reason why sky/openreach will not provision internet calls would be if you have a telecare line provisioned by the old copper line
Avatar for Sleepy7
Level 2 icon
No idea on speed, but Sky weren't able to continue hitting my agreed contract speed whilst still on Copper.  I understand about care lines we don't have one of those I just need to understand how if we don't need a new router, how the phone is physically going to be connected to get calls via the internet.
@Sleepy7
What speed were you getting on your old line?
Could you enter you full address below and post the table and notes after removing your address from the image
Avatar for Sleepy7
Level 2 icon
@Sleepy7
For FTTP the Q Hub will need replacing by a Sky Broadband Hub or Max Hub.
The ER115 Q model is actually compatible with FTTP itself (although this is undocumented) but cannot support Sky Talk Internet Calls as it doesn't contain an Analogue Telephone Adapter (ATA) which is why it doesn't have a handset socket.
@Sleepy7
The only products avallable are fttc vdsl however thats marked exception to getting a sogea line (internet calls) and full fibre fttp which needs internet calls
Could you check "my account" on your my sky app to see what your are getting
The exception on vdsl sogea may indicate sky/openreach cannot supply you with internet calls for other reasons unknown.  In which case i assume you will retain pstn line thru your mastersocket
@TimmyBGood
@TimmyBGood wrote:
@Sleepy7
Notice the exception in sogea i assume applies to fttp
@cookiemonsteruk
'FTTP is available' and being an FTTP priority area should override that.  The exception would be for very unusual circumstances.
Avatar for Sleepy7
Level 2 icon
@TimmyBGood
Hi both, thanks for your help, not too clear on the APP what I'm getting, it just says Superfast Broadband activation.  There is mention of a Sky hub, but no dispatch date yet.  Then on another page it mentions that I may not need a hub, I wish they would just give me a strainght answer.
If they are dispatching a hub, the FAQ say dispatch 3 to 5 days before installation so I hope I see a dispatch date this week.
@Sleepy7
