Discussion topic: Sky max pod speeds.
This message was authored by Ste82 This message was authored by: Ste82
Sky max pod speeds.
Hi I'm only getting between 60/80mb speeds on the sky max pod when I am getting 500mb for my hub. Are the pods capped at a slower speed ?
Re: Sky max pod speeds.
@Ste82 the pods are not capped but to get high speeds they need to be placed where they have a fast connection bsck to the hub. They use a third high frequency signal to connect to the WiFi Max hub which has limited range to give higher speeds so placement is important. I would experiment with moving the pod closer to the hub.
This message was authored by Alan07 This message was authored by: Alan07
I believe that the Sky Max Pod only uses WiFi 5 whereas the hub uses WiFi 6. There's a marked speed difference between the two.
Sky Q 2TB V3
4 x mini
LG 55OLEDC9PLA
LG SL9Y soundbar
@Alan07 thst is correct but given WiFi5 can easily deliver around 600Mb/s the restriction has little practical effect. As I posted earlier in the thred the biggest factor is the backhaul connection to the hub that primarily determines the speed the extenders can provide.
