Discussion topic: Internet keeps cutting out
Message posted on 05 Sep 2025 08:06 PM
My internet keeps cutting out. It's been doing it for a week now, I've followed all your steps on the app and it doesn't fix it. It will be working fine then suddenly it's gone sometime will be back after a few minutes but sometimes takes longer. Then the internet may work for a hour or few but then it cuts again but today it's been doing it all day like every 5/10/20 minutes
Message posted on 05 Sep 2025 09:51 PM
Re: Internet keeps cutting out
I am finding my internet keeps dropping and don't know why is there any one know how to fix it
Message posted on 06 Sep 2025 02:31 AM
Re: Faulty sky hub , Internet keeps dropping
I have been having issues with my sky broadband for months. I've rang and complained, changed back from max to super fast then discovered a fault on the line which got fixed swapped back to max and internet is still rubbish. Ive had enough of my WiFi cutting off and on off and on constantly. Considering leaving and going back to bt
Message posted on 06 Sep 2025 02:41 AM
Mine is exactly the same, been doing it for months
Message posted on 06 Sep 2025 04:59 AM
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
