Discussion topic: Sky Broadband Hub faulty port
Message posted on 05 Sep 2025 10:01 PM
When engineer installed full fibre he connected to the sky broadband hub box. The WAN Ethernet port is faulty and only worked when lay down. It now does not work at all.
Engineer recommended to request new box
Message posted on 06 Sep 2025 05:08 AM
Re: Sky Broadband Hub faulty port
Have you contacted Sky and done that? You definitely won't receive a replacement hub just by posting on here as we're fellow customers.
Message posted on 06 Sep 2025 07:21 AM
@DBynon definitely ask Sky for a replacement hub but in the meantime use one of the other ethernet ports as apparently they shouldcswitch to WAN mode but you msy need to reboot the hub.
