Discussion topic: No internet light on hub
Message posted on 29 Jul 2024 09:46 PM
No internet light on hub, try to reset the hub but not work
Message posted on 29 Jul 2024 10:40 PM
Re: No internet light on hub
@JjjennyCyy Can you please run the servuce checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Run a more updated broadband test by pressing on the broadband button on the service checker.
Message posted on 30 Jul 2024 12:38 AM
I try it, the result is there's problem with your Sky broadband, how can I do ? I can't connect the internet
Message posted on 30 Jul 2024 12:47 AM
This seems to be an ongoing problem,I've been told by sky they know there's a problem and I can cancel my subscription for broadband and try someone else
Message posted on 31 Jul 2024 01:28 AM
I call the sky technical team , solve the problem already, thank you
Message posted on 31 Jul 2024 08:36 AM
@JjjennyCyy What was the outcome of your issue?
