Discussion topic: No Internet, no Internet green light, and an orange light for voice
Message posted on 04 Sep 2024 01:03 PM
Message posted on 04 Sep 2024 01:57 PM
Re: No Internet, no Internet green light, and an orange light for voice
Hi @J9ndr
I've flagged your post to Sky, look out for a message on the forum
Message posted on 04 Sep 2024 02:22 PM
Hi there! Thank you for escalating this. We have sent an invite to @J9ndr.
Message posted on 04 Sep 2024 02:35 PM
I also have exactly the same issue - tests in the app are saying everything is fine but no internet connection on any devices
Message posted on 04 Sep 2024 02:36 PM
This is happening to me too
Message posted on 04 Sep 2024 02:38 PM
Exactly the same issue with mine !
Message posted on 04 Sep 2024 02:47 PM
I have no internet connection just a flashing green light.
Message posted on 04 Sep 2024 02:50 PM
Im having the same problem - tried restarting, unplugging and checking on the service status but it says everything is fine
@wlp1994 & @tash11 & @Liv96 & @007AM Can you please run the latter directions even if the service checker says green/good.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 04 Sep 2024 02:51 PM
We are having the sane issue as well
Message posted on 04 Sep 2024 03:27 PM
It's showing as an outage in my area but with very vague information - is there a way of finding out how close this is to being resolved or how long we're likely to be without internet for?
Message posted on 04 Sep 2024 03:49 PM
@wlp1994An outage is sorted out by Openreach and if it is an area wide outage it can take time with no time line to when it is done.
Message posted on 04 Sep 2024 03:50 PM
Same problem here
