Discussion topic: New broadband hub wall bracket
This message was authored by: Mart08
I was told by sky that my broadband hub was no longer supported for security and software updates, so on request they sent me a new sky broadband hub 4.2, it needs to go on the wall do sky supply wall brackets for the hub. Thanks
Re: New broadband hub wall bracket
@Mart08 no Sky do not provide any brackets for the Hub 4 you should be getting. Best position is standing on a surface or shelf so it is above obstructions like radiators.
This message was authored by: FLC
@Mart08
Ebay has them.
