11
This discussion topic has been answered Discussion topic: Netflix error nw-4-7
This message was authored by: AlinaS
My Netflix doesn't work on my Sony Bravia TV, it keeps showing this Error nw-4-7. It says that to restart my home network and streaming devices which I did. I also restore the TV to Factory Settings. I have no clue what else to do🙈.
Did anyone manage to deal with this issue before, please? TIA
Avatar for AlinaS
This message was authored by: AlinaS Answer
Re: Netflix error nw-4-7
My Sony TV is 10 years old too but I managed to solved the issue without buying a new TV 🙂 I bought a Fire TV Stick from Amazon. I can see almost everything Netflix, Disney+ and many other apps. I thought this my help others so you can keep using your old TV without spending a lot of money on a new one 🙂
Thanks for everyone that tried to help, I really appreciate it 🙏
Is Netflix working on any other device on your WiFi?
I am NOT a Sky Employee
Avatar for AlinaS
Yes, it works on our phone's and tablet. The issue is on the TV. It used to work very well before on our old address but we moved house and we also switched to Sky and the Netflix never worked on my TV at this address.
This message was authored by: Giggsy1977
Do other apps on the TV work?
Not a sky broadband subscriber
Avatar for AlinaS
Yes, Amazon prime.
If Prime works, the TV must be connecting to the router ok then...hmm...odd that!
Avatar for AlinaS
Yeah, annoying. Thanks anyway!
This message was authored by: John410
I have the same problem. Just happened a few days ago. Didn't move house but other apps etc working fine on the same tv. Netflix fine on another TV.
This message was authored by: Amber143
I'm also having the same problem, Sony Tv, works when using Netflix on Gemini from direct Tv, but not the tv itself and amazon prime app works through the tv, if anyone figures it out, please let me know, I haven't used Netflix from the TV we got this from my Husband’s Dad, I updated tvs software. It's easier to access from the tv button than from searching it in apps on the Gemini, but it's not a serious issue as I can still access it! It would be nice to know how to fix it though!
@Amber143
Are you in the uk?
I thought gemini was US,
Follow the steps below anyway
https://help.netflix.com/en/node/14560#:~:text=If%20you%20experience%20the%20error,there%27s%20a%20n....
This message was authored by: TameSquirrel
I have the same issue. Two Sony Bravia TVs, neither working with Netflix. Same error code although I'm not on Sky broadband. Netflix works on other devices in the house including other (non Sony) TVs. The standard steps don't work. This feels like a Sony software issue. Perhaps age of TV / no longer supporting latest version of Netflix? Mine are probably 10 years old. Just guessing. Very frustrating.
Avatar for AlinaS
