Discussion topic: My broadband has gone down so i will have no tv broadband or phone for 2 days . Thans a bunch sky
This message was authored by: DG47
New to sky so find this very frustrating
Re: My broadband has gone down so i will have no tv broadband or phone for 2 days . Thans a bunch sk
@DG47
How do you know it'll be down for two days?
This message was authored by: peter-marlow+1966
Do you have the my app on your  phone, if so run a broadband  service check for speed and any  problems  in the area
P c marlow
@DG47 appreciate it is frustrating but there many tens of millions of Openreach lines in the country and at any time several tens of thousands will have faults and unfortunately yours is one of them this weekend it is bad luck. Sky one of many isps that use the Openreach network so if you previous ISP used the same line the fault would have happened even if you had stayed with them and the repair would take the same time.
Openreach set SLAs for repairing line faults which for domestic lines is to repair within 2 working days after report or you are due compensation. What you use the line for doesn't matter as to Sky and Openreach it is a domestic connection. If you pay for a business connection the SLA is better but you will pay significantly more.
