38
This discussion topic is read only This discussion topic has been answered Discussion topic: Internet not working - Yorkshire
This message was authored by: Evans07
Service checker says no issues, router all green lights, devices connected okay but nothing loading on phones or TV.
Moderator note: Amended title to better reflect query
This message was authored by: Daniel-F Answer
Re: Internet not working - Yorkshire
Posted by a Sky employee
Hi all,
Thank you so much for your continued discussions & confirmation of location 🙂
Support teams have deployed a potential fix and are interested in any user feedback.
To get this, we ask any affected customers to please restart your router which should fix the issue.
Update 17/10: Having seen multiple users confirm that their issue is resolved from completing the step above we are now looking to lock this thread down.  If you are finding you are still having broadband issues, I recommend my original advice which was our service status page found here. From the status page you'll be able to check for any local issues and see our full help content for resolving any isolated problems you are having with your broadband just now.
If you are still having issues after the fact, please do start a new thread so other users can continue to offer you help separate to the resolved problem above 🙂
Thanks,
Daniel
Community Moderator
Locked
This message was authored by: hainz
Also having same issues
This message was authored by: Kat8888888
Same problem. A wired connection to a laptop is working but no WiFi to any devices. Don't want to restart router as I've had problems before and that's made it worse
This message was authored by: T1naS
I am having the same problem, orange light on hub, tried rebooting, work from home, this is not good
This message was authored by: Lmt123
Same issue what is going on
This message was authored by: Tiggerbird
Same issue , all green lights on router, all devices are connected but same issue saying no Internet.
Where all the lights on a Sky hub are green (or justvte voice light is amber) but data doesn't flow is caused by a fault in the server at Sky's end managing your connection. You can normally sort this by powering down the hub for an hour or using the disconnect function in the web interface of the black hubs.
Alternatively you can sometimes work round the issue by adding a public DNS address to your devices like lap tops and phones network set up I use Google's public DNS on 8.8.8.8 & 8.8.4.4
An amber internet light is not the same issue as that indicates the hub is not connected to the exchange. This troubleshooter can help https://www.sky.com/help/articles/hub-lights-explained-start
This message was authored by: DP01
I've got the same issue. All lights are green, can log on to the WiFi via devices, but then no access to internet.
This message was authored by: LindsayMilloy
sky says everything is fine but none of my devices can connect?
not the best when you're working from home!
This message was authored by: TheBobster
Morning, i have the same issue.  No changes made to the network since it was working last night.
Online service check says all ok.  (Well its not!)
All household devices connected to the router (i can see them in the router when logged into it)
No devices can connect to the interent (Wi-fi connected or hard wired)
Tried factory reset.  No change.
The only thing im not sure about is the Primary and Secondary DNS servers under menu 'Maintenance -> Diagnostics' in the router are both stating 0.0.0.0 ????  Is this right?
This message was authored by: JohnT20
  • Same here.
This message was authored by: geri22
Same issues here - I should not need to keep rebooting my WiFi system at home - it's not normal !
This message was authored by: Frank375
Same issue here in East Yorkshire
This message was authored by: Claire98765
Having the same issues. Can connect my mobile but nothing else? All green lights on the router.
Been on the phone to sky now for nearly 40 mins, turning things on and off- no further forward, suggesting I connect via an Ethernet cable but no idea where we've put it? Anyone else back online?
Locked
