Discussion topic: Internet keeps cutting out
This message was authored by: Zara18
Internet connection keeps dropping. I'm back at work tomorrow and work from home so it's vital that this is working. It's been doing this every few months. I dont even use WiFi on my phone at home as it's shocking!
Re: Internet keeps cutting out
@Zara18 Could you please post your router stats following the link below.
This message was authored by: JPR007
@Zara18 If you post your stats as mentioned then this will indicate if it's a line fault or simply local wifi. Sounds to me like it's the WiFi rather than a fault with the actual broadband connection.
Also to clarify...working from home has no bearing on anything. Sky and many other ISP's are giving you a domestic service, which has fairly pathetic SLA's (service level agreements), which won't make you a priority over anyone else. Of course there is nothing that says you shouldn't use it for work either.
If it is a line fault the standard target is 2 working days to fix from when the fault is logged with Sky.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
This message was authored by: toomster
My connection keeps dropping today in south wales.
This message was authored by: HolmesyBoyUK
Not sure if you mananged to get this sorted but I have been having the same problem - I spoke to Sky Broadband Support earlier this week and they told me to log onto http://192.168.0.1/ and then change my desired WIFI channel from Auto (to any of the other channels). He said that having it on Auto often causes the fault.
It's been fine since.
