6
This discussion topic has been answered Discussion topic: Home mesh wifi
This message was authored by: Gary125
Home mesh wifi
Considering a home mesh wifi system. Some have mentioned switching off Sky router wifi. Is this necessary? Are there any benefits/ disadvantages of doing this? Was minded to just ignore the additional wifi network
This message was authored by: cookiemonsteruk Answer
Re: Home mesh wifi
@Gary125
If you have sky q tv you could feasibly use 2.4 and 5 ghz for the sky q box comectivity and disable 2.4 ghz on a wifi 6 router eg asus rt ax models . In that way you have full use on sky q and run faster wifi 6 from the asus as wifi 6 has additional channels above the sky broadband hub . Otherwise disable wifi on the sky hub
Re: Home mesh wifi
@Gary125
The benefit would be freeing up channel space for your new mesh system. If you leave the Sky hub's WiFi on then it becomes a lot more difficult for your new system to find free channels
I am NOT a Sky Employee
Avatar for Gary125
Re: Home mesh wifi
Is this the same even if in Access Point mode?
Re: Home mesh wifi
@Gary125
The idea is to stop interference especially on the 2.4ghz wifi band
Re: Home mesh wifi
@Gary125
Yes, anything that broadcasts a WiFi signal.
Avatar for Gary125
Re: Home mesh wifi
Cheers everyone. I will have to work out how to switch of the wifi then
Re: Home mesh wifi
@Gary125
