Discussion topic: Internet issues
This message was authored by: Sarahwoods365
Internet issues
Internet keeps dropping.
Re: Internet issues
@Sarahwoods365 Could you please post your router stats following the link below.
This message was authored by: dale040290
Re: Internet issues
I cannot maintain a stable connection either. Here are my stats;
Router Statistics
System Up Time: 07:16:45
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time
WAN WANoE 286366 338515 0 25681 1453060 00:21:51
LAN Up 652402 444952 39 387136 87908 07:16:45
WLAN (2.4 GHz) Up 1285891 517311 0 2834572 43951 07:14:58
WLAN (5 GHz) Up 747022 184688 0 577500 392212 00:49:41
Broadband Link Downstream Upstream
Connection Speed 159900 kbps 30000 kbps
Poll Interval:
Seconds (at least 3s):
10
Re: Internet issues
@dale040290 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Re: Internet issues
I have tried this a on a number of occasions however it says there are no issues. I could be watching a YouTube video, be **bleep** through FB and it just buffers. I disconnect, reconnect, and it starts up again. I also have hard wired cameras, and they keep going offline. I have power cycled everything, and still no fix
Re: Internet issues
@dale040290  Can see there was a drop 21 minutes before you posted the router stats. Did you run the broadband test while the connection was dropped or while it was working?
Re: Internet issues
Tried doing it both when it happened and since
Re: Internet issues
@dale040290  So it has happened again since the last post ? Are you in the UK or Ireland?
Re: Internet issues
It's continuous tbh. I'm in south Wales
Re: Internet issues
@dale040290  I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
This message was authored by: Greenfingers001
Re: Internet issues
Thanks for escalating this. We’ve sent @dale040290 an invite to chat.
This message was authored by: bittu79
Re: Internet issues
internet not working from last night
This message was authored by: Addie15
Re: Internet issues
Update-We are closing this session now due to no further response. If you still need help, please let us know so we can re-escalate this for you. Thanks.
