4
This discussion topic has been answered Discussion topic: Installation new broadband
This message was authored by: Peter322
Our installation should be done by 13 October but is still not live do to a cables needed to install on outside of property still no any further updates?? What I need to do now ? 😠
This message was authored by: Highlinder Answer
Re: Installation new broadband
@Peter322  When was the last time you called for an update? If it is outside work then that would be down to Openreach, but you will need to speak to Sky again for updates.
@Peter322  What has Sky told you in updates when calling them after the failed installed date?
Avatar for Peter322
The employee told me that I will be informed when they do fix the problem nothing since I don't know what I need to to I need internet !
Avatar for Peter322
I will call them today again 😕
