10
This discussion topic has been answered Discussion topic: I need a new cable for modem
This message was authored by: Damo4
I need a new cable going from telephone box to modem
Avatar for Damo4
This message was authored by: Damo4 Answer
Re: I need a new cable for modem
Can I just have phone number be a lot easier
Avatar for Damo4
I need a new modem cable
This message was authored by: Padam_Padam
You'll need to be more specific. What type of broadband do you have? Full fibre? Is it with Sky? What kind of router/hub do you have? Which cable exactly?
Avatar for Damo4
I need a new modem cable dog chewed through mine
There can be various cables connected to your router. We need to know which one. Power? Ethernet? RJ11? You are probably quickest getting replacements from a local electrical shop - they are all standard cables. Only the power supply cable will be trickier to replace.
Avatar for Damo4
150 from a Sky landline or mobile.
Avatar for Damo4
I don't use a sky mobile or land line
If you can describe your current broadband setup, we could tell you which cable is appropriate so you didn't have to call.
This message was authored by: Deag
The forum does not allow sky phone numbers to be posted, they get removed.
You can get your desired phone number by using the "Contact us" link...
https://www.sky.com/help/articles/contacting-sky
