Discussion topic: I cannot connect my eufy camera away from home
Message posted on 02 Feb 2024 09:38 AM
Hi all
I cannot connect my eufy camera away from home when I switch to sky boardband. It work perfect before by vrigin media.
I can view the video clip/live stream at home network but is not work away home. I already turn off all the sheild and firewall I can setup from the apps and router.
Any idea?
Regards
Message posted on 02 Feb 2024 11:39 AM
Re: I cannot connect my eufy camera away from home
@Adam94 Which router do you have from the link below that Sky sent you for your broadband service.
Message posted on 02 Feb 2024 01:00 PM
Thank you for your reply
They send me Sky hub
Message posted on 02 Feb 2024 01:02 PM
Message posted on 02 Feb 2024 02:06 PM
@Adam94 How long have you been with Sky? Did you join recently?
Message posted on 05 Feb 2024 08:45 AM
Message posted on 06 Feb 2024 08:31 AM
@Adam94 If that was the Sky broadband hub that you have. Then you might have to split the Wi-Fi frequencies. This can be done following the link below.
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Message posted on 06 Feb 2024 10:55 AM
@Adam94 are you using the eufy app to access your camera?
Message posted on 06 Feb 2024 11:59 AM
Does it work while you are at home?
Also please do not turn the firewall off on your Sky hub that is very dangerous
