10 Dec 2024 03:14 PM
10 Dec 2024 03:19 PM
White or black Sky Hub?
Unsynchronizing and renaming bands isn't possible on the white Max Hub.
For the black hub you can seperate the wifi as below for the white hub you need to temporarily disable the 5ghz
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
11 Dec 2024 09:37 AM
It's the white hub
11 Dec 2024 09:41 AM
Posted by a Superuser, not a Sky employee. Find out more@Skye89 you cannot separate the WiFi bands on the white Sky hub. Instead if you have devices thst wont connect to the dualband SSID is tontemporarily turn off tge 5GHz band connect tge device to the hub and then turn the 5GHz band again. The switch to that is in the My Sky app navigatecto product options chosectge Sky Max hub and Sdvanced settings.
11 Dec 2024 11:28 AM
But it will work though? I'm still in the cooling off period and more than happy to leave sky
11 Dec 2024 12:01 PM
Posted by a Superuser, not a Sky employee. Find out more@Skye89 the only way to know is to try it as it depends on your devices. You have 31 day cooling off period from activation.
11 Dec 2024 03:10 PM
Thanks, yes I did that using the admin option as the app doesn't let me do any of this. They said it would work today but nothing yet
11 Dec 2024 03:13 PM
Posted by a Superuser, not a Sky employee. Find out more@Skye89 Sky tell us the app is back working but you may havecto close and re-open it.
