Discussion topic: HARDWARE VPN CISCO AND WHITE SKY ROUTER
This message was authored by: felix2009
Hi
i I cannot get, after hours with sky tech on the phone, my works Cisco vpn to connect via the new sky hub I got this week
it's a silver Cisco box ISR 1100 which I plugged into the back of my old black sky router with no issues
my work IT saying sky need to remove any fire walls from the sky router and ensure they allow us to build IPSec tunnels
anyone help???
thsnks
Re: HARDWARE VPN CISCO AND WHITE SKY ROUTER
@felix2009 Can you not just put the old sky hub back on, or is there another reason?
@felix2009
Typically an issue associated with the Sky use of Map-T IPv4 address sharing on circuits with a Sky Max Hub.
https://helpforum.sky.com/t5/Broadband/Having-problems-with-a-3rd-party-VPN-and-have-a-Hub-6/td-p/48...
Avatar for felix2009
Well upgraded to the new one as supposed to be quicker so would like to try and fix...
@felix2009
You need to follow the advice in the link above to get Sky to remove Map-T and provide a unique IP address (although this still won't be a fixed address as that's not available on domestic Sky broadband)
Ah ok so need this really to happen:
Alternatively, you can log into your account via this form, to request a change to your service which will resolve the problem for you.
how do I escalate that?
just via the form which I just did and wait?
@felix2009 Follow the advise from @TimmyBGood
