Discussion topic: Wifi Signal Keeps Dropping
This message was authored by: Nads01
Wifi signal keeps dropping and just had Sky installed today!
I need to do my work and my laptop was getting a poor signal, same on my phone and pulled out another laptop and same issue.
Reset didnt make a difference.
Losing out on pay because of this! 😡
Re: Wifi Signal Keeps Dropping
@Nads01 Losing the will to live would be a better description, from what to what did you do, and what sky hardare do you have on whatever connection type. Ethernet connected would be the best start in the short term!, you are aware that until midnight off the install activation date is the possible time for it all to settle down!
