This discussion topic has been answered Discussion topic: Door camera
Message posted on 20 Jan 2026 04:53 PM
Message posted on 24 Jan 2026 08:37 PM
Hello again. Just to let you know that the problem is now solved. I switched off the power to the rouuter and fibre box for a few minutes, then restarted and set up my door cameras and it worked. It took a while for the router and fibre to reboot. Thank you again for all your help.
Message posted on 20 Jan 2026 05:36 PM - last edited: 20 Jan 2026 05:37 PM
Re: Door camera
@GeordieJohn72 Did you change the sky hub on your fibre upgrade and which hub do you have now and previous, see the link below abot the current ones! Also did the hub move by far when you did the upgrade and where your new ONT was positioned!
Message posted on 20 Jan 2026 05:46 PM
Re: Door camera
I have the black router. I didn't change it's position. The guys who fitted the fibre said it was well placed. The problem is that I am unable to find a 2,4 ghz partition anymore. The upgrade is brilliant. Just this one problem is all. Thanks for responding.
Message posted on 20 Jan 2026 06:00 PM - last edited: 20 Jan 2026 06:01 PM
Re: Door camera
@GeordieJohn72 Did you look at the link, they are all black apart from 2 off them will assume you have the sky Broadband Hub, as full fibre and talk requires that one, so linked below about the split bands for you on that hub!
Message posted on 20 Jan 2026 06:09 PM
Re: Door camera
Yes. The sky engineers went through this detail with me whilst doing the work. Im quite prepared to consider that the camera is at fault and not the fibre. Just unable to find the 2.4 partition anymore is all. Thanks again for your interest.
Message posted on 21 Jan 2026 07:45 PM
Re: Door camera
Message posted on 21 Jan 2026 07:52 PM
Re: Door camera
@GeordieJohn72 Your were sent the information link on post 4, did you not see it did you just skipped it!
If your installation Engineer reset you sky Hub when he changed the position then it defaults to what is on the label back off the sky Broadband Hub! Split band;s no longer and back to a single ssid!
Message posted on 21 Jan 2026 07:56 PM
Re: Door camera
Trouble is...I'm 79 years old with poor eyesight...easy to skip stuff. lol. Will reread all and learn how to split them. Thanks for your help.
Message posted on 24 Jan 2026 08:47 PM
Re: Door camera
@GeordieJohn72 Well done, it's whatever it takes to get it all working again! Re-boot on the Hub is circa 5 minutes from power on to ready...
Message posted on 14 Sep 2026 06:47 PM
Re: Door camera
No problem resolved
