13
This discussion topic has been answered Discussion topic: WiFi keeps dropping out...
This message was authored by: Bob1992
The WiFi keeps dropping out. I've lost count of the amount of times I've reset the router. It was working fine until someone down the road and Fibre connected to their house and now mine is being beyond unreliable. I changed to Fibre because it was meant to be more reliable and faster, only had it a couple of weeks and it's been rubbish. Any suggestions are welcome but I would prefer Sky to get in contact and resolve this for me.
Re: WiFi keeps dropping out...
All,
When there are broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
This message was authored by: Hanna10
Same here!
This message was authored by: William-Tugwell
Not alone on this one as this has happen to me for 3 nights in a row now at the same time of 1:40am and it's starting to bother me as not had this problem for 4 months and even then it use to do it once.
This message was authored by: Amy2004
Same here. It's getting annoying at this point
This message was authored by: BShaw2310
Same here it's starting to **bleep** me off. I do late night work that I need my wifi for and this disconnecting is really causing issues. SKY sort it out!!!!
This message was authored by: MAGGIE2110
Mines dropped too and has been off for over 15 minutes. For someone who cant sleep due to pain, the Internet is very much needed. Come on sort it out Sky.
Hi 👋 When I moved our Sky was rubbish, it wasnt reaching the correct speed. I got in contact with Sky and they gave me a booster, for a cost. This still didnt solve it and as I work from home I insisted they came out again. Sure enough another booster was given for a further charge! So far its working. I think its unfair that the speed they said it such reach, wasnt and I have to foot the cost. If I had time, patience and didnt need the Internet everyday for work, id change suppliers. Good luck x
This message was authored by: Om7
Same problem here
Oh look its dropped again! Seriously Sky what is going on?!
All,
Maintenance we get but it happening 3 nights in a row is not normal so we should at least be told what is happening, also that whole resetting our routors thing never works as every time I have or unplugged the internet wire out of the wall it still doesn't fix the problem so I end up waiting and hoping it works in the morning. To me that info just seems like outdated rubbish from a old tech manual and nothing against those saying it but it just makes people more bothered having to read that is the only way to fix a problem.
This message was authored by: PearlOlive
Mine has been dropping out all day. Never had this issue before. Having to use my hotspot as MS teams calls arent stable at the moment.
Openreach and therefore ISPs do not announce overnight maintenance and won't tell you why it's taking place.
My post did say try rebooting the hub if it's still down after 7am, in which case maintenance may not be the cause.
@PearlOlive
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
