Discussion topic: Broadband super slow
This message was authored by DeepakR This message was authored by: DeepakR
Hi Team,
Really getting frustrated the internet is super slow for a year and half now..Nobody tried to helps..
thanks,
DR.
Re: Broadband super slow
@DeepakR  Black or white router from Sky?
DeepakR
Black colour..
@DeepakR Could you please post your router stats following the link below.
DeepakR
ttings use the menus at the top of this page.
  • Select Show Statistics to see your Sky Hub performance statistics such as the number of packets sent and number of packets received for each port
  • Select Connection Status to see information about your current connection
Systems Detailshelp
Manufacturer Sky
Model ER110
Firmware Version 4.03.0704.R
DSL Firmware VersionA2pv6F039m1.d24m
Modemhelp
Modem StatusConnected
DownStream Connection Speed15412
UpStream Connection Speed1274
VPI0
VCI38
IPv6 Loopback Address2a02:c7c:f433:c400::1/128
Broadband Porthelp
MAC Address70:50:af:43:58:6a
IPv4 Address2.216.152.105
Network TypePPPoA
IPv4 Subnet Mask255.255.255.255
Gateway IPv4 Address2.127.238.242
IPv4 Domain Name Server90.207.238.97, 90.207.238.99
Gateway IPv6 Addressfe80::22
IPv6 Domain Name Server
IPv6 Global Address2a02:c7c:f433:c400::1/64
IPv6 Link Local Addressfe80::7250:afff:fe43:586a
IPv6 Delegated Prefix2a02:c7c:f433:c400::/56
LAN Porthelp
MAC Address70:50:af:43:58:69
IPv4 Address192.168.0.1
DHCPv4On
IPv4 Subnet Mask255.255.255.0
IPv6 ULAfd82:5884:de5f:0:7250:afff:fe43:5868/64
IPv6 Link Local Addressfe80::7250:afff:fe43:5869
DHCPv6On
Wireless Porthelp
Name (SSID) SKY138AC
Region Europe
Current Channel 1 (2.4 GHz), 36 (5 GHz)
Wireless APEnabled
Broadcast NameYes
Connection Status Show Statistics
DeepakR
DeepakR
Hi ,
Any luck with the screen shots?
thanks,
DR.
This message was authored by HiHowAreYa This message was authored by: HiHowAreYa
Your router stats say your on a ADSL broadband package. It is very slow compared to everything these days.
DeepakR
That's right..what is the option now? anything I had to do from my side?
thanks,
dr.
Sky haven't sold ADSL packages for a long time. You need to upgrade to ultrafast fibre.
@DeepakR
Could you enter you full postal address below and post the table and notes below after removing your address from the image
DeepakR
Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability WBC SOGEA Availability High Low High Low       VDSL Range A (Clean) DeepakR_0-1723562786578.gif
80 75.9 Unavailable Available VDSL Range B (Impacted) DeepakR_1-1723562786578.gif
80 74  Unavailable Available G.fast Range A (Clean) DeepakR_2-1723562786578.gif
-- -- -- -- -- Unavailable -- G.fast Range B (Impacted) DeepakR_3-1723562786578.gif
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process FTTP on Demand 330 50 -- Available --
Other Offerings Availability Date VDSL Multicast Available
Exchange Product Restrictions Status FTTP Priority Exchange Y WLR Withdrawal Y SOADSL Restriction N
@DeepakR
@DeepakR
"80 75.9 Unavailable Available VDSL Range B (Impacted) "
You should be able to upgrade to a good 80Mbps superfast connection.
DeepakR
Please do the favor..I'm tired for almost than year now..
Perhaps I'm reading those results wrong.
To me it says VDSL and fttp not available as it's impacted.
I think @DeepakR needs to investigate what 5g mobile broadband is available.
Need to see which mobile phone operator has a 5g tower near to you.
