Discussion topic: Broadband stopped working completely GL5. Anyone else having problems?
Message posted on 03 Feb 2025 01:52 AM
Re: Down again GL5, same time as last night. Anyone else?
Same in GL10 too. 2nd night now.
Message posted on 03 Feb 2025 01:53 AM
Re: Broadband stopped working completely GL5. Anyone else having problems?
Yes - GL10 too
Message posted on 03 Feb 2025 01:56 AM
Mine doesn't again in stroud
Message posted on 03 Feb 2025 02:05 AM
Keeps telling me to try checking my cables and reset the router
Message posted on 03 Feb 2025 02:24 AM
Dursley here, checker says all OK, router says different. Annoying as hell as only had it back today from the last outage 😣
Waste of time, spent 3 hours following their instructions. It won't bear any fruit. Expect the 'something is not working, oops, sorry' message when their office staff get in at 09:00am.
Until then, you'll just be gaslit by the troubleshooting into believing you can remedy the cluster... mess, yourself.
all the best
Message posted on 03 Feb 2025 02:30 AM
Dursley as well and down again.. maybe they doing maintenance on the fault.
I work from home so need it working..
Message posted on 03 Feb 2025 02:33 AM
Decided to post here first from now on before spending any energy plugging and unplugging! Peace of mind at least that it's out of my hands 🙌
Thanks everyone for chiming in 👍
Message posted on 03 Feb 2025 02:41 AM
GL6 here but woke up and went to check something and yes, Broadband is off and as you say, about same time as last night. Sky service checker says all okay. Pleased I seen your comment though as it suggests it is their end, not mine. It's very odd.
Message posted on 03 Feb 2025 02:54 AM
Yep its down like it was lastnight, same problem its Sky's end all we can do is wait. I got a upstream and downstream connection speed connected and active to the fiber box but no connection to Sky so its their end.
Message posted on 03 Feb 2025 02:55 AM
Yep down in the entire Gloucestershire area or so. Mine went down again just like lastnight.
Message posted on 03 Feb 2025 03:06 AM
same here in doncaster, south yorkshire. suddenly down from 02:50am.
Message posted on 03 Feb 2025 05:44 AM
Re: Internet dropped again 2nd night
It could be overnight maintenance taking place.
If it still down later then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
