6
This discussion topic has been answered Discussion topic: wi fi new max hub
This message was authored by: steveblue8
wi fi new max hub
Hello
just had sky fibre installed, all went well,
but my 5g mobile phone keeps displaying 2.4ghz
if i turn wi fi off on my phone and back on 5ghz appears ?
do i need to change anything in the sky hub settings ?
any help would be appreciated,
Thanks steve
Re: wi fi new max hub
@steveblue8 wrote:
but i have a 5g phone 3ft away from the router so i would imagine it should use 5ghz ?
Note that 5G is entirely unrelated to 5Ghz WiFi.
5G is 'fifth generation' cellular technology while 5Ghz is a frequency band.
A 5G phone might well also be equipped for 5Ghz domestic wireless connectivity, but the similarity in naming is a coincidence.
This message was authored by: Doc5907
@steveblue8 wrote:
Hello
Thanks steve
@steveblue8
As long as its working okay I wouldn't worry about the band. If you do run into an issue then lowering the security in the musky app might help.
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for steveblue8
Level 3 icon
Ok thanks for your help
i appreciate it
steve
@steveblue8 you look to be confusing two technologies. 5G (fifth generation) is the latest technology Mobile providers use. WiFi which is the signal from your Sky hub is different but uses two wave bands a longer range but slower 2.4GHz and the faster 5GHz band which sounds similar but in this case simply means the radio frequency used. 5GHz band signals have less range as they do not pass through walls etc as well.
Level 3 icon
Hello
thanks for your reply, i understand what you are saying
another thing my wi fi washer worked perfectly with my old sky router on 2.4ghz
now it will not connect because my phone states in the washer app you are using 5ghz
and must switch to 2.4ghz to connect your washer ?
so i give up
Level 3 icon
Hello i sort of understand
but why does my phone switch between 2.4ghz and then 5 ghz?
or am i just thick lol
