54
This discussion topic is read only This discussion topic has been answered Discussion topic: Broadband Issues 10th May 2024
Thread created to colate issues
This message was authored by: Daniel-F Answer
Re: Broadband Issues 10th May 2024
Posted by a Sky employee
Hi all,
Thank you for posting over the 10th regarding the broadband issues you were experiencing.  There is some indication this was resolved and with that I'll be looking to now lock this thread moving forward.
If you are finding you are still experiencing any issues with your broadband, please perform the line test here: https://www.sky.com/pages/sky-com/test-your-broadband to check for any known issues at your local exchange.
If you do need further help after this, feel free to start a new thread with your own specific issue 🙂
Thanks,
Daniel
Community Moderator
Locked
This message was authored by: JoeT95
WiFi not working
WiFi is down sky to working all fine but no WiFi connection Kirby cross essex
This message was authored by: Rabinlivi
Fibre down in Ladywell Livingston
Sy fibre has dropped around 8:20pm, tried resetting in normal way but still not working, according to musky app all is good but it isn't.
This message was authored by: North3rnLight5
Re: Fibre down in Ladywell Livingston
Same in Eliburn
This message was authored by: Julezcat
Experiencing the same issue , tried re setting the normal way still not working. All checks are working according to website
This message was authored by: Sully807
Re: WiFi not working
I'm in Maidstone kent and my wifi keeps cutting in and out all day, it's frustrating to say the least. Sky's technical help is crap to be polite about it
This message was authored by: Mustan123
It's down in Eliburn as well
@Rabinlivi  & @Julezcat  & @North3rnLight5  Is this information from the service checker or the broadband test you are getting this information from?
This message was authored by: TUBBS1970
Internet down in Bracknell
Rg12 area Internet down ? cant find any info to why or for how long ?
Re: Internet down in Bracknell
@TUBBS1970 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
This message was authored by: Trynity
Same. App broadband check shows all fine but checked on router and shows broadband disconnected.
This message was authored by: Rupinder
Sky broadband has dropped in Birmingham. Since 20.25. It dropped an beforehand. It has been doing this for the past week at least. Very annoyed as I work from home.
Service checker
I've checked the service checker every time - no problems anywhere
This message was authored by: leem63
Internet down in Deans too
Locked
