Discussion topic: Broadband Issues 10th May 2024
Message posted on 10 May 2024 10:17 PM
Re: Fibre down in Ladywell Livingston
From the sky app and sky.com when I check my connection and WiFi. Each time it reports as no issues down..
Message posted on 10 May 2024 10:18 PM
Re: Broadband Issues 10th May 2024
Thanks for the info.
I don't suppose there is any way of knowing if it's a sky or openreach issue. I need to find a reliable provider as I work from home and can't afford outages.
Message posted on 10 May 2024 10:19 PM
Sky app is telling me there is an issue now, but on the website it's all good apparently 😂
Message posted on 10 May 2024 10:20 PM
BT fibre is also down in Murieston - Virgin may be the answer as they have their own cables
WiFi connection keeps going. Happened multiple times throughout the day, just loses connection on multiple devices, even the sky box, then comes back.
Each time the broadband checker says "no issues".
This is in saltash
Message posted on 10 May 2024 10:23 PM
I was considering virgin media, but heard horror stories about their reliability too.. not much incentive to.be reliable if there is no better option unfortunately!
Someone will be along to reset a hub somewhere and cross their fingers until it dies again a week later. Sorry, I work in IT, I know how it is 😂
Message posted on 10 May 2024 10:28 PM
I moved from Virgin about a year ago and it was more reliable but costly hence move to Sky ! Connectivity just hasnt been the same tho
Message posted on 10 May 2024 10:49 PM
Back up now, but for how long?
Message posted on 11 May 2024 09:06 AM
Wifi on the blink
Is anyones wifi on the blink?
Message posted on 11 May 2024 09:30 AM
WiFi in Chertsey not working - what can I do?
Woken up to no WiFi KT16 area. No known problems in the area. What should I do? Tried switching off and on again!
Message posted on 11 May 2024 09:31 AM
Re: WiFi in Chertsey not working - what can I do?
@Brooksie50 wrote:Woken up to no WiFi KT16 area. No known problems in the area. What should I do? Tried switching off and on again!
Have you rebooted your router as well as the puck?
Message posted on 11 May 2024 09:32 AM - last edited: 11 May 2024 10:17 AM
Then you'll know that a system with multiple single points of failure cannot be considered 'reliable': that's as true for any Openreach ISP as it is for Virgin, because on neither network are customers prepared to pay enough for redundancy in local equipment or data routing.
Message posted on 11 May 2024 10:02 AM
Have been Getting the same thing in Kent both Thursday a few times and a lot yesterday too, app says all OK, sky make it very hard to actually find a person to talk to, appalling really
Message posted on 11 May 2024 01:06 PM
Isn't 10th anymore but my broadband has been going off between 7pm-2am for the past week. When I use all the checkers everything seems to be fine, yet everything disconnects from wifi, it can be once and then come back on a few seconds later to continously going off and on for hours. Paying a fair bit for this and its ridiculous now
Message posted on 11 May 2024 01:26 PM
For disconnections which occur regularly at particular times it's worth investigating if there's anything locally working on the same kind of timing: typical suspects might be a central heating pump or microwave oven, for example.
