Discussion topic: Broadband Boost and Sky Stream
Message posted on 31 Dec 2023 07:30 PM
So, moved to Sky Stream to save money as Q prices were jumping so much.
but... Q is a wifi extender and the layout of our house is quite a large footprint. So stream wouldn't work in bedroom and office was low signal.
Turned a Q mini back on and it was fine, spoke to Sky they sent a booster to replace the Q mini.
great, but I cannot get it to connect, press the two WPS buttons but no joy. Sky support couldn't detect and error so assumed the booster was faulty, they sent another one and same happening. Frankly I wasn't to throw the thing through a window and go buy my own booster... but I think Sky should be able to sort this out.
am I doing anything stupid? Measures already taken:
- off and on (router and booster)
- reset (router and booster)
- replaced booster
- placed booster closer to the router circa 3 m
Message posted on 31 Dec 2023 08:15 PM
Re: Broadband Boost and Sky Stream
Booster needs to be closer, ideally within a foot when using the wps pair, try that.
Message posted on 31 Dec 2023 08:44 PM
Cheers Jim, still no joy.
no where near as easy and when I used Deco with a BT hub....
.... might did that out and put it through that.
Message posted on 31 Dec 2023 08:51 PM
What is the model of your router ie SR203 upright black color, and booster ie SE210 white color and upright like the router.
Press wps on router, watch led flash, press wps on booster and let them pair, takes about 1 minute or more for them to sort each other out, after all 3 led's light on booster.
Message posted on 31 Dec 2023 08:53 PM
It's the stand up black router and white booster as you say, both WPS flashing orange but never connect always only have 2 green lights on the booster, never red or orange to show any error just off - same with previous and this one.
Message posted on 31 Dec 2023 09:01 PM
Press the reset button only on the booster for 30seconds, it is located on the back panel near the Ethernet jack if the booster has one, new model does not.
Then re-pair via wps side of each unit.
The fact that you have left and right green led's and not the middle looks like
the wifi has paired to the router, but the internet has not.
Let the wps on both finish, when the cycle is over both the wps router and booster led's wil go out.
Message posted on 31 Dec 2023 09:06 PM
link to the sky broadband booster help click below
Message posted on 31 Dec 2023 09:08 PM
Thanks Jim have been through all these so guessing it's yet another painful call to Sky.
They won't be getting the q mini back until this all works!!
Message posted on 31 Dec 2023 09:10 PM
Question, in all of your attempts, have you ever reset the router?
Message posted on 31 Dec 2023 09:11 PM
Message posted on 31 Dec 2023 09:12 PM
Yep but will do all again too! Wondering if q mini box being on still causes an issue so tomorrow will essentially start from beginning. Reset everything and turn q off and have it close etc.
Message posted on 31 Dec 2023 09:20 PM
When you reset the router, watch the front led's. one begins to flash rapid, this lets you know that the router has actually reset to the factory settings. should be a link will try to find and post.
don't remember if the booster does the same on a reset, i had to reset both mine at sky request
3 months ago, think that it re-paired on the 2nd or 3rd attempt, and i did have to move them closer
i would say that they were 2 feet apart, they would not pair in the operating positions, about 30' were
booster has allways been, no way would they pair....
Once paired up moved back to operating position no issue's.
You could be right, q mini is on and causing issue, so switch the sucker off.
Let me know how you get on, best of luck not a good time to be doing all of this....
Jim
Message posted on 31 Dec 2023 09:28 PM
from the hub help below...
Reset a Sky Hub, Sky Q or Sky Broadband Hub (your hub’s black)
- Hold Reset on the back of your hub for about 30 seconds or until the lights on the front blink.
- Wait for the power, wifi and internet lights to go green again.
- After your hub has reset and the lights have gone back to normal, switch it off and on again at the mains. It’s to make sure you can still make and receive calls.
Good to know: This will reset all your hub's setting including your WiFi password, so if you've changed it from its default you'll need to change it again.
Message posted on 31 Dec 2023 10:27 PM
And from the booster help
To reset a Sky Q Booster or Sky Broadband Booster?
- Hold RESET on the back of your booster for ten seconds or until the power light flashes green.
- When the power light turns solid green, it's reset.
Message posted on 31 Dec 2023 10:32 PM
And final part before you throw it out the window
Connect your booster
- Plug the blue end of the power cable into the blue port on the back of your booster. Then plug into the mains and switch on.
- Wait until the power and wireless lights turn green.
- Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on your hub for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
- After a few minutes, the connected light will turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your hub.
