This discussion topic is read only Discussion topic: Waiting for TV Schedule
This message was authored by: Davejersey
Since early this afternoon I can only access recorded shows and catch up on my sky Q box...I have followed all the instructions and it's still showing this...
Locked
This message was authored by: Doc5907
Re: Waiting for TV Schedule
@Davejersey
Try to reboot your Q box.
Press Standby on your Sky Q remote and then switch off and unplug at the mains.
Wait at least 30 secs and then switch your Sky Q box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait a few seconds before you press Home on your Sky Q remote which should change the light to green and home screen should appear.
Sky Q 1TB UHD
LG TV
Sky Mobile
@Davejersey The mini TV in your picture say no satellite signal so your dish might be out of alignment. You may need to arrange an engineer.
Avatar for Davejersey
Thanks for the tip...have done this 4 maybe 5 times in the last hour...nothing
Only every seem to have problems when sky have a new product to release...can't help being suspicious 🤨
@Davejersey  as @Daniel0210 suggested, looks like its time to call Sky
Sky Q 1TB UHD
LG TV
Sky Mobile
This message was authored by: Islla
our picture is showing same as above waiting for tv schedule.
This message was authored by: LGUser
@Davejersey  and @Islla  If you need help with getting the phone number to call Sky, go this page & scroll to the bottom and expand the link need more help https://www.sky.com/help/home
Locked
