This discussion topic is read only Discussion topic: Previous series
This message was authored by: ChrisXchurch
Previous series
Sky Q user - Is there a way to watch previous series - I was going to watch "The Split"  but after downloading i find it is Series 3 Episode 1 - but i can not see how to watch series 1 & 2 - is there a way??
Locked
Re: Previous series
@ChrisXchurch  If it's not available on Catch up/On Demand, then no as it is likely it's been removed.  Have you searched for it?
Re: Previous series
hi @ChrisXchurch
as the the Split is from the BBC best place to look for it is the iPlayer - where all seasons are currently showing
Avatar for ChrisXchurch
Re: Previous series
New to Sky Q i have not found a way to search??
Re: Previous series
The magnifying button below the Record button (on the latest remotes)
or Voice search - although I have sometimes found the voice search does not always return content that is available for some reason
Neither search will show content in iPlayer
Re: Previous series
Hi @ChrisXchurch
Get to grips with Voice control on Q.   Search and also control
See the following links
https://www.sky.com/help/articles/using-text-search-on-your-sky-q-box
https://www.sky.com/help/articles/sky-q-voice-control-commands
This message was authored by: LGUser
Re: Previous series
@ChrisXchurch  Yes, The Split seasons 1-2 are available to download or stream using BBC iPlayer.
If you have a voice remote, press the blue button (or the button on the side of the remote) and once the line at the top of the screen has gone across the scree, just say "The Split".
Locked
