726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: Littlelegs1986
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Hi im in the north east same issue stuck on sky cinema. My daughter has autism and her morning routine been disrupted by this! Thankfully ive managed the voice control to find peppa pig to divert major upset
This message was authored by: LChenery
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Hi, try this - if you press mic button and ask for a channel of your choice it gets round the streaming issue. Good luck.
This message was authored by: benbunter
Re: Turned on my sky glass this morning, it loaded the A to Z sky cinema screen.
had less than a week and mine doing this today, tried reset keeps going back to a-z cinema screen
This message was authored by: sewell
Re: Only getting A-Z sky cinema on sky glass
Using remote voice control ask to "show playlist" which shows your playlist and includes favourite channels. So you can see what's on now for favourite channels and select a channel.
This message was authored by: Peter+Han
Re: “sorry, there are currently no programmes of this type available”
Same here, nightmare !
Re: Sky glass home page
@chelseafc10
Many posts on this fault. Sky are aware and are working on it. Use your voice remote & say tv guide, works that way until Sky fix it apparently.
Re: Sky Glass not work
It's a fault a Sky's end. They are aware of the fault and are investigating. Voice control still works, until it's fixed.
This message was authored by: Kev+Smith+76
Re: My sky glass says, sorry, there are currently no programmes of this type available.
seems to be fixed
This message was authored by: MIveson
It's so annoying, had nothing but issues since buying the TV. Appears it's not the best purchase and more of a headache.!!!!
This message was authored by: David+Tillbrook
Re: Tv not doing anything
Cheers guys
Re: Can’t get Home Screen goes to sky cinema can only access by saying sky guide, or playlist etc. h
@MartinBok
This message was authored by: MissNind
Re: The Home Screen on Sky Glass isn’t working
Same is happening for me. Voice control working but not anything else. Rebooted twice but nada. I guess it's a Sky issue since there are many of us having the issue so hopefully it's resolved soon.
Re: Sky Glass no main menu despite restarting
@JohnDeans
This message was authored by: Row+G
Yugo2007..which HDMI port is your Firestick using? Tried mine for the first time in our Glass tv and it kept losing the internet within a minute of being turned on. .?
This message was authored by: Alex+Ricote
Appears to have been sorted now?
Locked
Answered - Go to Answer
