726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
Re: Sky remote Home button not working.
Sky are aware of the fault and are investigating.
This message was authored by: Squidgytabboggan
Re: Sorry, there are currently no programs of this type
Found some other posts does seem to be a wider a problem but the trick of pressing the mic button on the remote and asking for 'sky guide' did allow me to get live tv again
This message was authored by: Tilly+43
Re: Turned on my sky glass this morning, it loaded the A to Z sky cinema screen.
Mines doing the same except 1 puck is working OK.
This message was authored by: Jacqui1266
Re: The Home Screen on Sky Glass isn’t working
Same here ,same message ,same problems
This message was authored by: BenRtt
Re: Sky glass menu not working
My remote has also stopped working and the TV has stopped responding to voice input. Voice control is not the workaround for everyone.
This message was authored by: JLC23
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
My Sky Glass is stuck on A-Z Sky Cinema choice and no menu/apps showing. I hve done reset and everything to no avail. Using the mike button is a work around but Sky need to fix the issue.
Just another nail in the coffin for Sky Glass.
Re: Home screen showing only a few movies and that's it
@TPCawood84
Many posts on this fault. Sky are aware and are working on it. As you say use your voice remote & say tv guide, works that way until Sky fix it apparently.
This message was authored by: Jazzbarro
My sky glass isn't properly working
This message was authored by: DJBSuffolk
Yup same here on sky stream!
Re: Sky glass not working#%*
Sky are aware of the fault and are investigating. Voice control is still working.
This message was authored by: MIveson
Sky Glass not work
It appears loads of people are having the same issue; Sky glass TVnot work and programmes are not connecting. Can you provide some advice how I can get this working. Starting to regret buying this TV as its constantly down.!!!!
Re: Sky glass
@mummymick
Many posts on this fault. Sky are aware and are working on it. Use your voice remote & say tv guide, works that way until Sky fix it apparently.
This message was authored by: Georgia30
Yes mine is exactly the same, how annoying. Hopefully will be sorted soon. Would hate to be sky this morning all the phone calls lol
To summarise this is a fault at Sky's end which is being fixed as fast as possible. Rebooting etc will not help but voice control works for most people but if using the remote speak into the mic which is at the top. If voice isnt working you can access search by pressing ....
Edit system appears to be back up and running at my end. Try pressing home.
This message was authored by: Beez09
I found with the problem until they fix you can talk to the remote and say BBC iPlayer or Netflix, or you can press the 3 dots on the remote search a program and it launches the app and the program. Sure there will be a fix soon but show that sky need a fail safe default Home Screen if no connection or their service goes down to make it a workable tv
Locked
Answered - Go to Answer
