Discussion topic: Sky Glass/Stream Homepage Problems
Message posted on 03 Feb 2023 08:01 AM
Re: Sorry there are no programmes of this type available
Morning,
do we just have to wait? Or do we need to ring and report it?
thanks
Re: Sky glass menu not working
Hi
mines same and I've spoken to family and all having same issues. I've tried everything on help section nothing has worked
Re: My sky glass says, sorry, there are currently no programmes of this type available.
Let's hope they fix it soon.
Re: Sky glass not working#%*
Not just you.
Looks like there's a problem at sky's end.
Same problem, voice control still works.
Message posted on 03 Feb 2023 08:02 AM
Having the same problem
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Hi, if you press mic button and ask for a channel of your choice it gets round the streaming issue. Hopefully works for you.
Perfect makes me feel better that it's not just me thank u ☺️
Re: Turned on my sky glass this morning, it loaded the A to Z sky cinema screen.
Same with my tv this morning. Hope this gets sorted soon!
Message posted on 03 Feb 2023 08:03 AM
Re: Sky freezing on a film page
Hi thanks- yes I had already been using voice button which is fine. Had to leave TV to travel to work but now thread lots of similar posts. I had once before and not sure if I accessed it through using voice button to take me into settings and then doing something.
I have got a message when I try and press the home button "sorry there are currently no programmes of this type available".
Tried turning on and off at the wall and still not working.
Voice control working to get to specific tv channel
Re: Hello does anybody know how long it takes for a sky glass tv to reset im waiting nearly an hour
Many posts on this fault. Sky are aware and are working on it. Use your voice remote & say tv guide, works that way until Sky fix it apparently.
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Same situation here since around 6AM. Have found these pucks a little unreliable in terms of crashes, app issues and now this. Hopefully teething problems as, when it works, this is the perfect solution for us.
Same......
Same here in London. Most frustrating.
