Discussion topic: Sky Glass/Stream Homepage Problems
Message posted on 03 Feb 2023 07:58 AM
Re: Sky glass has crassed, it wont show any options, just shows A-z of sky,
The tv is stuck on sky cinema I've turned the TV off on three occasions I have tried the home button nothing is working
Re: Sky glass menu not working
Thank you that has helped me and it is better than nothing 😊
Re: Has anybody else got a problem with sky glass being stuck on sky cinema? Both main tv and puck
We've also had exactly the same problem after the TV underwent an update this morning. I tried a factory reset which didn't work. You can still use the voice control button to get to the guide and access all channels and apps. It feels like Sky are still experimenting with Glass!
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Same here. Looks like everyone with Sky Glass is affected. Using voiced command to watch anything at the moment 😕
Re: Sorry there are no programmes of this type available
I have got the same issue but have been able to use my voice button to get to channel. Not ideal but hopefully it will get sorted soon. Seems to be all of U.K. I belong to a Sky Glass Facebook group and it's being reported lots on there
Re: My sky glass says, sorry, there are currently no programmes of this type available.
Thanks thats works but when you press the home button it takes you back to the error message again. It must be a UK Wide Sky Glass issue. I hope the get it resolved asap.
Re: Menu screen
Good morning @lilmissj ,
I'm sure they'll be looking into it.
Especially with the widespread outcry from customers.
Cheers,
Jamie
Re: Only getting A-Z sky cinema on sky glass
Same here
Exactly the same here, stuck on A to Z of cinema screen, knocking off wifi didn't work, unplugging tv didn't work, factory reset didn't either.
navigation possible with microphone
Message posted on 03 Feb 2023 07:59 AM
Re: The Home Screen on Sky Glass isn’t working
The same has happened with mine. Use voice control to open up the TV guide, you can select a channel from there.
Refund for what?
Re: Sky stream stuck on A-Z of sky cinema
Out of interest.. how was this post marked as 'the answer' as it isn't a fix for the issue and isn't an update from Sky with a fix eta
Same problem an two sky stream devices. Only getting sky cinema screen, no Home Screen.
I have exactly the same problem and have also tried switching off the sky glass and restarting my router
This fault affects everyone while Sky fix it use voice control which works.
