Discussion topic: Sky Glass/Stream Homepage Problems
Message posted on 03 Feb 2023 07:41 AM
Re: Sky glass menu not working
Mines the same this morning, stuck on sky cinema menu, voice control works though to get the channel we want.
Message posted on 03 Feb 2023 07:42 AM
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Are sky fixing the issue with sky glass tv
Re: Sky glass has crassed, it wont show any options, just shows A-z of sky,
It worked I've got music on thank you 🙌🙌🙌
Re: The Home Screen on Sky Glass isn’t working
MIne is stuck on the Sky Cinema screen and my voice control isn't working. Did anyone find a fix?
Sky glass not working
Message on Home Screen saying
"Sorry there are currently no programmes of this type available "
Just blue screen
Anyone else help??
Re: Sky glass screen stuck on sky cinema, won’t load from remote
My sky glass is also stuck on sky cinema cant go back nothing I tried unplugging tv a few times nothing
Not channels
Hello
I've got up this morning to no channels on my glass TV , Ive unplugged it and left it unplugged and still no channels . Bill is also paid
Have anyone got any ideas what's going on
Message posted on 03 Feb 2023 07:43 AM
Not yet. Still the same. Only could use voice control-say TV guide...
Re: After rebooting 6 times sky glass and puck box, cannot connect to sky
@Wincobank no need to reboot the issue is at Sky's end use voice control which works.
Re: Sorry there are no programmes of this type available
Brilliant thank you.
Re: Sky stream stuck on A-Z of sky cinema
Mine is the same. Definitely an error at Sky's end. Hopefully they'll fix today.
Message posted on 03 Feb 2023 07:44 AM
Glad I am not the only one...
perhaps they are doing the update to instal the updates for individual playlists...
thank god for voice commands remote!
Phew thought it was just mine . Tried everything to sort .. was panicking about having to watch Happy Valley on a laptop on Sunday 😂
Re: Not channels
@robnnikki multiple posts reporting a system wide fault.voice control will load a channel for you eg "BBC One"
Having the same issue, I cannot get this message off. I've tried turning TV off and the internet and this doesn't help at all - anybody else having this issue??
