726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: Jamie+Mc+D
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Having the same issue myself, unfortunately a weakness has been pointed out with Sky Glass.... If it's not connected to the service you don't seem to be able to use another media option like Blu Ray/DVD player or even Xbox. I think I will be returning mine and swapping my contract.
This message was authored by: Claire381
Re: Sky glass menu not working
Hi,
My glass is only loading sky cinema menu and won't load anything else.
Tried resetting router and tv, remote speech is working but won't load live tv programs only apps or playbacks etc.
This message was authored by: 125Croydon
Re: Has anybody else got a problem with sky glass being stuck on sky cinema? Both main tv and puck
Yes we have the same issue, happened before and quick fix was to turn unit off and restart the unit. Sadly this has not worked this time, must be a bigger problem. Will have to watch Batman rather than Kay Burley this morning.
This message was authored by: DCARTER-UK
Re: Can’t load sky glass
Sky app turned back time too....LOL
This message was authored by: Jncdnc
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Did a reset also as new to sky stream puk& all was working ok at 12.30am , got up at 5.30 to this issue . Thought we'd done something but looks like there are a lot of us with the same issue. Hope Sky get it sorted soon
This message was authored by: Lizzie82
Thanks for that.
luckily I'm off to the gym now and can take my frustration out there but I feel like had a work out after spending from 6-630 this morning troubleshooting
This message was authored by: Uk+roadie
Same here tried unplugging to reset but it's the same!! Never had any issues with tv wired
This message was authored by: Tomo369
Were having the same issue too
This message was authored by: Bears+Fan
Same here
Re: No programs available
@Suvs given the large number of posts all reporting the samething no need to start a new thread. Its a fault at Sky's end rebooting your box etc wont cure it. In the meantime use voice search/control and watch whatever you want.
This message was authored by: cathy1980
I have the same issue but speaking into the remote you can get BBC one. By saying Play BBC One
This message was authored by: Ingrids
Mines the same.  I've had to use voice to get to TV channels
I'm thinking the same to be honest as already been having issues having to keep switching it off at the mains or it just freezes and it then resets itself
This message was authored by: Alison-jane1
Re: Only getting A-Z sky cinema on sky glass
same!!!! 😩
This message was authored by: Naomi8621
I've woken to my tv doing the same. Tried turning off tv at wall but no diff.
You can use the voice on remote to open a tv channel.
Not impressed given the amount i pay for this subscription
Locked
Answered - Go to Answer
