Discussion topic: New Firmware QS012 - support for bluetooth head sets.
Message posted on 25 Oct 2022 06:42 AM
The roll out of QS012 firmware has started with at least one significant change which is a new option on Glass TVs where you can link a Bluetooth audio device via/Settings/Connected Devices/ where a third option Bluetooth device now appears. This should help anyone with a bluetooth hearing aid or headphones and should be independent of the main audio output but I haven't tested that.
Only had a quick check but I cannot see any other changes including the promised picture improvements or changes to the Playlist but they could well be in the firmware but not activated.
If Sky follow normal roll out plan around 5% of units will have updated another small batch will update the following week then the whole fleet of both Stream pucks and Glass TVs within a couple of weeks or so.
You will know when it completes which will be when @Anonymous finally has the new firmware.
Message posted on 25 Oct 2022 06:46 AM
Re: New Firmware QS012 - support for bluetooth head sets.
Great - thanks @Chrisee the Bluetooth feature is a much requested update! Keep us informed if you spot any other new features
@Anonymous you should be getting 11 soon then 😂
Message posted on 25 Oct 2022 09:49 AM
@Chrisee @Jporch316 will let you all know in about 2 - 3 weeks time when the roll out is complete🤣
Message posted on 25 Oct 2022 10:29 AM
Looks like the programme info bars have had subtle changes too. The info now floats in a box rather than the full width of the screen, same with the watch from start prompt.
Also the play / pause bar has had a slight refresh with cleaner icons.
Message posted on 25 Oct 2022 10:34 AM
On this week now also appears underneath available episodes rather than being a separate tab. So looks like this update provides quite a few cosmetic changes rather than 'big features'
Message posted on 25 Oct 2022 10:41 AM
Hopefully some much needed bug fixes 🤞
Message posted on 25 Oct 2022 12:04 PM
Hopefully they have focused on bug fixes more then looks
Message posted on 25 Oct 2022 02:22 PM
Is it possible to force a manual update?
Thank you in advance
Steve
Message posted on 25 Oct 2022 02:27 PM
You won't be able to force yet as it's a new release. It'll soon be here for all.
My Glass TV did update today to version 11.008 puck still on 11.007
Message posted on 25 Oct 2022 02:35 PM
Okay, thank you for the info
Message posted on 25 Oct 2022 07:08 PM
@Chrisee @Anonymous @Anonymous
mine has also updated to qs011-08 overnight ???
is this an intermediary stage for 12?
did you notice this @Chrisee before the update
navigaring the menus seems a lot more jerky since the update
Message posted on 25 Oct 2022 07:21 PM
Message posted on 25 Oct 2022 07:26 PM
My glass tv is a bit too expensive and big to throw out the window 😂
Message posted on 25 Oct 2022 07:30 PM
Still on 011.007
Message posted on 25 Oct 2022 07:51 PM
@Jporch316 went from QS011.07 to QS012. There are a number of changes one is a slightly longer times to lock a stream. It maybe that has been lengthened to improve reliability. It is probable 11.08baddres a specific issue which is also dealt with in QS012 but that is a guess.
