Discussion topic: Download Failed technical fault
Message posted on 16 Nov 2022 09:19 PM
Re: Good doctor episodes no longer downloading
@KG2KD2011 wrote:
Please can someone help I am half way through watching the good doctor on sky witness & got to series 2 episode 13 & it has stopped downloading & when I try & download it says download failed item unavailable however all the episodes are listed up to series 6 but none of the ones after series 2 episode 12 will download?! All settings are fine, I've turned on & off again, re-inserted card but no joy, all other programmes are downloading no problem, can anyone help?!
Hi @KG2KD2011
Check your Recordings - Most recent section for any failed downloads.
Any you find want completely deleting from the Recordings - Most recent section and also the deleted section in Manage.
Message posted on 16 Nov 2022 09:21 PM
Re: Download Failed technical fault
Just found this on another thread for the same issue in the past. Worth a try?
First make sure that you have no Failed downloads in your Recordings - Most recent section or the Deleted selecting in Manage. Any you find want completely deleting.
'Also Check that the Downloading section in manage is empty with no stalked or paused downloads.
Then Try a Reset Settings in the hidden menu.
Only Carry out the first Reset (Reset Settings) as the other two will wipe all recordings. After the Reset you will have to re pair your Bluetooth remote If you use one.
Message posted on 16 Nov 2022 09:26 PM
Re: Constant failed on demand
Finally got it working after constant resetting xx
Message posted on 16 Nov 2022 09:27 PM
@KG2KD2011 wrote:Please can someone help I am half way through watching the good doctor on sky witness & got to series 2 episode 13 & it has stopped downloading & when I try & download it says download failed item unavailable however all the episodes are listed up to series 6 but none of the ones after series 2 episode 12 will download?! All settings are fine, I've turned on & off again, re-inserted card but no joy, all other programmes are downloading no problem, can anyone help?!
@KG2KD2011 I tried episodes after 12 of season 1 and it would download in UHD but not in HD or SD. I guess you don't have the UHD add on though.
All I can suggest is emailing Sky Viewer relations at viewerR@sky.uk
Sky Q 1TB UHD
LG TV
Sky Mobile
Re: Technical Fault Download
What are you trying to download, i can download movies but all tv programmes are showing a technical issue.
Message posted on 16 Nov 2022 09:28 PM
Rob and Romesh. It's on now 🤷♂️
Message posted on 16 Nov 2022 09:29 PM
exactly what i wanted to download, then tried some other stuff and also not working.
Message posted on 16 Nov 2022 09:35 PM
some stuff will download, rob v romesh and italia 90 documentary wont on mine now, everything else ive tried has started.
Exact same problem trying to download on demand sky witness.
Have reset Router, main Sky Q and mini hub boxes in every possible combination and all downloads FAIL... was hanging on phone to Sky for that long with no answer they kindly disconnected the call at 9pm becuase they were closed. 🤷🏻♂️.
Judging by the times of some of the posts this evening by everyone else, I'm guessing Sky either have no idea or no one currently working on the issue!
Netflix and all other streaming content appears to be working fine, just Sky who can't get their act together...
Message posted on 16 Nov 2022 09:39 PM
I can not download anything again apart from movies. Do you have movies to try, surely cant be a coincidence that this is all happening at the same time
Message posted on 16 Nov 2022 09:45 PM
Sky TV Demand Download Failed
Trying to download via on demand services and it's saying download failed. This is happening on Sky Max and Sky witness.
have reset sky Q box and router and still an issue.
any ideas?
Message posted on 16 Nov 2022 09:47 PM
Good to know. Does resetting the box lose important settings and recordings?
Re: Sky TV Demand Download Failed
Seems to be a big issue, looks like your thread number 4 on this issue, all non sky content seems fine.
Message posted on 16 Nov 2022 09:48 PM
Yeah same problem here. Everything else works fine sky cinema included. Seems for me sky max sky docs and sky Atlantic are the problems.
Message posted on 16 Nov 2022 09:49 PM
Mine not working either.
Absolute joke sky. Sort your stuff out
