Discussion topic: Download Failed technical fault
Message posted on 16 Nov 2022 08:35 PM
Re: Trying to download a sky max program, keeps saying download failed...we have Internet connection
Yes same, it's weird
Message posted on 16 Nov 2022 08:36 PM
Re: Constant failed on demand
Same problem with a Ethernet connection on sky broadband started tonight
Message posted on 16 Nov 2022 08:39 PM
Seems to be a sky problem as other people commenting same fault. Oh well Netflix it is
Message posted on 16 Nov 2022 08:41 PM
Re: Good doctor episodes stopped downloading & say failed item unavailable half way through seri
This board is for glass and stream not Q or +.
Postinv in the relevant board will help you get a speedier resolution.
Message posted on 16 Nov 2022 08:45 PM
Same here
Message posted on 16 Nov 2022 08:48 PM
Not sure why the other poster would not be more helpful. Seems sky is down multiple users reporting same fault different channels, internet connections etc. I'd say sky has a problem with their service.
Message posted on 16 Nov 2022 08:49 PM
Re: Download failed
Exactly the same thing here. Can't download anything on sky, trying to play Chicago Fire s9 ep16, but now found nothing downloads.
internet connection is fine and checked status on sky q box.
Message posted on 16 Nov 2022 08:53 PM
Re: Download failed
Seems to be a sky service fault multiple reports of download failure on multiple platforms. Mine started at 8pm
Message posted on 16 Nov 2022 08:56 PM
Re: Slow download on sky Q - tried everything!
So as of this evening it's back to not being able to download anything again, I've done all the **bleep** troubleshooting steps, which obviously do nothing.
Meanwhile the apps build into my smart tv play immediately without buffering in full 4K HDR. Funny that!
Message posted on 16 Nov 2022 08:58 PM
Downloads failed, on demand
No matter which programme is selected. Absolutely nothing will download from the on demand section. Everything has been tried, restarting box, resetting settings, disconnecting wifi and restarting a new connection. Box will record TV programmes but refuses to download! Infuriating to say the least! Paying for services that can't be used. I've searched the forums and have found I'm just one of many in a long long list of complaints of the same nature...
Re: Technical Fault Download
Is yours working yet?
Message posted on 16 Nov 2022 08:59 PM
...and the same here. On Sky FTTP and using an Ethernet connection to the router. Internet connection is fine and none Sky downloads are working. Just Sky channels failing repeatedly.
Message posted on 16 Nov 2022 09:01 PM
No. Did a hard reset. Engineer in a week
Message posted on 16 Nov 2022 09:13 PM
Re: Download Failed technical fault
I have the same issue, can't download anything... it starts downloading then says failed after 1 second of downloading.
treid numerous series to see if it was just that particular one but it is all the series
Message posted on 16 Nov 2022 09:15 PM
Good doctor episodes no longer downloading
Please can someone help I am half way through watching the good doctor on sky witness & got to series 2 episode 13 & it has stopped downloading & when I try & download it says download failed item unavailable however all the episodes are listed up to series 6 but none of the ones after series 2 episode 12 will download?! All settings are fine, I've turned on & off again, re-inserted card but no joy, all other programmes are downloading no problem, can anyone help?!
